Size: 2.5 x 18
Design Span (L): 27.75 ft.
Clear Span: 27.50 ft.
Total Span: 28.00 ft.
Selfweight: 585.5 lbs
Dist. Selfweight: 21.10 plf
Total Weight: 590.8 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.190c - - - - -
Beam Design 2024A238
6/17/2024 1
b = 2.500 in.
d = 18.000 in.
A = 2.500 x 18.000 = 45.00 in.2
Sx = (2.500)(18.000)2/6 = 135.00 in.3
Sy = (2.500)2(18.000)/6 = 18.75 in.3
Ix = (2.500)(18.000)3/12 = 1215.00 in.4
Iy = (2.500)3(18.000)/12 = 23.44 in.4
6/17/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [45.00 x (333.00 + 3)] x (12 in./ft.)3 = 17.50 ft3
Volumespan = N[A x L] = 2 x [45.00 x 333.00] x (12 in./ft.)3 = 17.34 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.50 = 590.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.34 = 585.5 lbs
Distributed Self Weight (ws) = = 21.10 plf
  ws = 21.10 plf
27.75 ft.
27.50 ft.
28.00 ft.
2745.41 lbs
2745.41 lbs
6/17/2024 3
Cfu = = 1.190
Fby' = (1450)(1.15)(1)(1)(1)(1.190) = 1985.0 psi
fb = = 6040.4 psi
 fb = 6040.4 psi > Fby' = 1985.0 psi  (CSI = 3.04)   ➜  NG
6/17/2024 4
Fvy' = (230)(1.15)(1)(1) = 304.75 psi
fv* = = 44.67 psi
 fv* = 44.67 psi < Fvy' = 264.50 psi  (CSI = 0.17)   ➜  OK
fv = = 45.35 psi
 fv = 45.35 psi < Fvy' = 264.50 psi  (CSI = 0.17)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
6/17/2024 5
ΔLL = = 17.79 in.
(L/d)LL = 333.00 / 17.79 = 19
 ΔLL = 17.79 in = L/19 > L/360   ➜  NG
ΔTL = = 34.89 in.
(L/d)TL = 333.00 / 34.89 = 10
 ΔTL = 34.89 in = L/10 > L/240   ➜  NG
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 18 x 3 = 54.00 in2
fc⊥ = = 25.4 psi
 fc⊥ = 25.4 psi < Fc⊥y' = 560.00 psi  (CSI = 0.05)   ➜  OK
6/17/2024 6
