Size: 3.125 x 12
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 5000 lbs
Dead Load: 1500 lbs
Selfweight: 145.1 lbs
Dist. Selfweight: 17.58 plf
Total Weight: 149.5 lbs
Beam Design 2024A235
6/13/2024 1
b = 3.125 in.
6/13/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [37.50 x (99.00 + 3)] x (12 in./ft.)3 = 4.43 ft3
Volumespan = N[A x L] = 2 x [37.50 x 99.00] x (12 in./ft.)3 = 4.30 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.43 = 149.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.30 = 145.1 lbs
Distributed Self Weight (ws) = = 17.58 plf
5000 lbs
1500 lbs
  ws = 17.58 plf
8.25 ft.
8.50 ft.
3324.73 lbs
3324.73 lbs
6/13/2024 3
fb = = 1084.5 psi
 fb = 1084.5 psi < Fbx' = 2760.0 psi  (CSI = 0.39)   ➜  OK
6/13/2024 4
fv* = = 66.10 psi
 fv* = 66.10 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 66.45 psi
 fv = 66.45 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
6/13/2024 5
ΔLL =   =   = 0.06 in.
(L/d)LL = 99.00 / 0.06 = 1587
 ΔLL = 0.06 in = L/1587 < L/360   ➜  OK
ΔTL =   =   = 0.08 in.
(L/d)TL = 99.00 / 0.08 = 1204
 ΔTL = 0.08 in = L/1204 < L/240   ➜  OK
fc⊥ = = 177.3 psi
 fc⊥ = 177.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
6/13/2024 6
