Size: 5.125 x 12
Design Span (L): 17.10 ft.
Clear Span: 16.85 ft.
Total Span: 17.35 ft.
Live Load: 250 plf
Dead Load: 80 plf
Selfweight: 246.6 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 250.2 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.099c - - - - -
Beam Design 2024A231
6/8/2024 1
b = 5.125 in.
6/8/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (205.20 + 3)] x (12 in./ft.)3 = 7.41 ft3
Volumespan = N[A x L] = 1 x [61.50 x 205.20] x (12 in./ft.)3 = 7.30 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.41 = 250.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.30 = 246.6 lbs
250 plf
80 plf
  ws = 14.42 plf
17.10 ft.
16.85 ft.
17.35 ft.
2987.83 lbs
2987.83 lbs
6/8/2024 3
Cfu = = 1.099
Fby' = (1450)(1.15)(1)(1)(1)(1.099) = 1832.8 psi
fb = = 2875.8 psi
 fb = 2875.8 psi > Fby' = 1832.8 psi  (CSI = 1.57)   ➜  NG
6/8/2024 4
Fvy' = (230)(1.15)(1)(1) = 304.75 psi
fv* = = 68.24 psi
 fv* = 68.24 psi < Fvy' = 264.50 psi  (CSI = 0.26)   ➜  OK
fv = = 71.82 psi
 fv = 71.82 psi < Fvy' = 264.50 psi  (CSI = 0.27)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
6/8/2024 5
ΔLL = = 2.23 in.
(L/d)LL = 205.20 / 2.23 = 92
 ΔLL = 2.23 in = L/92 > L/360   ➜  NG
ΔTL = = 3.08 in.
(L/d)TL = 205.20 / 3.08 = 67
 ΔTL = 3.08 in = L/67 > L/240   ➜  NG
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 12 x 3 = 36.00 in2
fc⊥ = = 83.0 psi
 fc⊥ = 83.0 psi < Fc⊥y' = 560.00 psi  (CSI = 0.15)   ➜  OK
6/8/2024 6
