Beam Design - GLB
Size: 3.125 x 12
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Selfweight: 142.9 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 145.1 lbs
Beam Design M G 2437 MODESTO TEST
1/18/2024 1
b = 3.125 in.
1/18/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (195.00 + 3)] x (12 in./ft.)3 = 4.30 ft3
Volumespan = N[A x L] = 1 x [37.50 x 195.00] x (12 in./ft.)3 = 4.23 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.30 = 145.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.23 = 142.9 lbs
  ws = 8.79 plf
16.25 ft.
16.50 ft.
1516.28 lbs
1516.28 lbs
1/18/2024 3
fb = = 970.7 psi
 fb = 970.7 psi < Fbx' = 2760.0 psi  (CSI = 0.35)   ➜  OK
1/18/2024 4
fv* = = 52.38 psi
 fv* = 52.38 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
fv = = 59.73 psi
 fv = 59.73 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
1/18/2024 5
ΔLL = = 0.19 in.
(L/d)LL = 195.00 / 0.19 = 1007
 ΔLL = 0.19 in = L/1007 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 195.00 / 0.36 = 548
 ΔTL = 0.36 in = L/548 < L/240   ➜  OK
fc⊥ = = 161.7 psi
 fc⊥ = 161.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.25)   ➜  OK
1/18/2024 6
