Beam Design - 38 May St Biddeford
Grade: SPF SS
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 70 plf
Dead Load: 30 plf
Selfweight: 103.8 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 105.5 lbs
Beam Design Matt Higgins 2024A227
6/4/2024 1
6/4/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (189.00 + 3)] x (12 in./ft.)3 = 3.63 ft3
Volumespan = N[A x L] = 3 x [10.88 x 189.00] x (12 in./ft.)3 = 3.57 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.63 = 105.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.57 = 103.8 lbs
70 plf
30 plf
ws = 6.59 plf
15.75 ft.
15.50 ft.
852.74 lbs
852.74 lbs
6/4/2024 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1) = 1725.0 psi
fb = = 1006.1 psi
 fb = 1006.1 psi < Fbx' = 1725.0 psi  (CSI = 0.58)   ➜  OK
6/4/2024 4
fv* = = 35.63 psi
 fv* = 35.63 psi < Fvx' = 155.25 psi  (CSI = 0.23)   ➜  OK
fv = = 38.59 psi
 fv = 38.59 psi < Fvx' = 155.25 psi  (CSI = 0.25)   ➜  OK
6/4/2024 5
ΔLL = = 0.45 in.
(L/d)LL = 189.00 / 0.45 = 418
 ΔLL = 0.45 in = L/418 < L/360   ➜  OK
ΔTL = = 0.69 in.
(L/d)TL = 189.00 / 0.69 = 275
 ΔTL = 0.69 in = L/275 < L/240   ➜  OK
fc⊥ = = 63.2 psi
 fc⊥ = 63.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.15)   ➜  OK
6/4/2024 6
