Size: 2.5 x 7.5
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 50 plf
Selfweight: 138.5 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 140.7 lbs
Beam Design 2024A225
5/31/2024 1
b = 2.500 in.
d = 7.500 in.
A = 2.500 x 7.500 = 18.75 in.2
Sx = (2.500)(7.500)2/6 = 23.44 in.3
Sy = (2.500)2(7.500)/6 = 7.81 in.3
Ix = (2.500)(7.500)3/12 = 87.89 in.4
Iy = (2.500)3(7.500)/12 = 9.77 in.4
5/31/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [18.75 x (189.00 + 3)] x (12 in./ft.)3 = 4.17 ft3
Volumespan = N[A x L] = 2 x [18.75 x 189.00] x (12 in./ft.)3 = 4.10 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.17 = 140.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.10 = 138.5 lbs
50 plf
  ws = 8.79 plf
15.75 ft.
15.50 ft.
1070.34 lbs
1070.34 lbs
5/31/2024 3
fb = = 1062.0 psi
 fb = 1062.0 psi < Fbx' = 2760.0 psi  (CSI = 0.38)   ➜  OK
5/31/2024 4
fv* = = 38.80 psi
 fv* = 38.80 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
fv = = 42.14 psi
 fv = 42.14 psi < Fvx' = 304.75 psi  (CSI = 0.14)   ➜  OK
5/31/2024 5
ΔLL = = 0.22 in.
(L/d)LL = 189.00 / 0.22 = 864
 ΔLL = 0.22 in = L/864 < L/360   ➜  OK
ΔTL = = 0.59 in.
(L/d)TL = 189.00 / 0.59 = 323
 ΔTL = 0.59 in = L/323 < L/240   ➜  OK
fc⊥ = = 71.4 psi
 fc⊥ = 71.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.11)   ➜  OK
5/31/2024 6
