Grade: SPF SS
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 50 plf
Selfweight: 60.4 lbs
Dist. Selfweight: 4.39 plf
Total Weight: 61.5 lbs
Beam Design 2024A223
5/31/2024 1
5/31/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (165.00 + 3)] x (12 in./ft.)3 = 2.11 ft3
Volumespan = N[A x L] = 2 x [10.88 x 165.00] x (12 in./ft.)3 = 2.08 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.11 = 61.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.08 = 60.4 lbs
50 plf
ws = 4.39 plf
13.75 ft.
13.50 ft.
905.76 lbs
905.76 lbs
5/31/2024 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.2)(1)(1) = 1725.0 psi
fb = = 1396.3 psi
 fb = 1396.3 psi < Fbx' = 1725.0 psi  (CSI = 0.81)   ➜  OK
5/31/2024 4
fv* = = 55.96 psi
 fv* = 55.96 psi < Fvx' = 155.25 psi  (CSI = 0.36)   ➜  OK
fv = = 61.35 psi
 fv = 61.35 psi < Fvx' = 155.25 psi  (CSI = 0.40)   ➜  OK
5/31/2024 5
ΔLL = = 0.28 in.
(L/d)LL = 165.00 / 0.28 = 586
 ΔLL = 0.28 in = L/586 < L/360   ➜  OK
ΔTL = = 0.73 in.
(L/d)TL = 165.00 / 0.73 = 227
 ΔTL = 0.73 in = L/227 > L/240   ➜  NG
fc⊥ = = 100.6 psi
 fc⊥ = 100.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.24)   ➜  OK
5/31/2024 6
