Beam Design - window C header
Grade: SPF No.2
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Selfweight: 40.7 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 42.1 lbs
Beam Design S S 2110
5/29/2024 1
5/29/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (87.00 + 3)] x (12 in./ft.)3 = 1.45 ft3
Volumespan = N[A x L] = 2 x [13.88 x 87.00] x (12 in./ft.)3 = 1.40 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.45 = 42.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.40 = 40.7 lbs
ws = 5.61 plf
7.25 ft.
7.00 ft.
7.50 ft.
677.28 lbs
677.28 lbs
5/29/2024 3
Fbx' = (875)(1.15)(1)(1)(1)(1.1)(1)(1) = 1106.9 psi
fb = = 332.9 psi
 fb = 332.9 psi < Fbx' = 1106.9 psi  (CSI = 0.30)   ➜  OK
5/29/2024 4
fv* = = 27.86 psi
 fv* = 27.86 psi < Fvx' = 155.25 psi  (CSI = 0.18)   ➜  OK
fv = = 35.39 psi
 fv = 35.39 psi < Fvx' = 155.25 psi  (CSI = 0.23)   ➜  OK
5/29/2024 5
ΔLL = = 0.02 in.
(L/d)LL = 87.00 / 0.02 = 3877
 ΔLL = 0.02 in = L/3877 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 87.00 / 0.04 = 2147
 ΔTL = 0.04 in = L/2147 < L/240   ➜  OK
fc⊥ = = 75.3 psi
 fc⊥ = 75.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.18)   ➜  OK
5/29/2024 6
