Grade: 24F-V8 1.8E DF/DF
Size: 2.5 x 6
Design Span (L): 32.25 ft.
Clear Span: 32.00 ft.
Total Span: 32.50 ft.
Live Load: 1000 lbs
Dead Load: 75 lbs
Selfweight: 113.4 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 114.3 lbs
Beam Design 2024A213
5/29/2024 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
5/29/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (387.00 + 3)] x (12 in./ft.)3 = 3.39 ft3
Volumespan = N[A x L] = 1 x [15.00 x 387.00] x (12 in./ft.)3 = 3.36 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.39 = 114.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.36 = 113.4 lbs
1000 lbs
75 lbs
  ws = 3.52 plf
32.25 ft.
32.00 ft.
32.50 ft.
594.65 lbs
594.65 lbs
5/29/2024 3
fb = = 7299.5 psi
 fb = 7299.5 psi > Fbx' = 2760.0 psi  (CSI = 2.64)   ➜  NG
5/29/2024 4
fv* = = 59.24 psi
 fv* = 59.24 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
fv = = 59.42 psi
 fv = 59.42 psi < Fvx' = 304.75 psi  (CSI = 0.19)   ➜  OK
5/29/2024 5
ΔLL =   =   = 14.91 in.
(L/d)LL = 387.00 / 14.91 = 26
 ΔLL = 14.91 in = L/26 > L/360   ➜  NG
ΔTL =   =   = 17.08 in.
(L/d)TL = 387.00 / 17.08 = 23
 ΔTL = 17.08 in = L/23 > L/240   ➜  NG
fc⊥ = = 79.3 psi
 fc⊥ = 79.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.12)   ➜  OK
5/29/2024 6
