Beam Design - Front Beam
Size: 3.125 x 12
Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Live Load: 500 plf
Dead Load: 150 plf
Selfweight: 116.5 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 118.7 lbs
Beam Design Clayton Crites Horvath - Deck
5/28/2024 1
b = 3.125 in.
5/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (159.00 + 3)] x (12 in./ft.)3 = 3.52 ft3
Volumespan = N[A x L] = 1 x [37.50 x 159.00] x (12 in./ft.)3 = 3.45 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.52 = 118.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.45 = 116.5 lbs
500 plf
150 plf
  ws = 8.79 plf
13.25 ft.
13.00 ft.
13.50 ft.
4446.85 lbs
4446.85 lbs
5/28/2024 3
fb = = 2313.2 psi
 fb = 2313.2 psi < Fbx' = 2760.0 psi  (CSI = 0.84)   ➜  OK
5/28/2024 4
fv* = = 148.23 psi
 fv* = 148.23 psi < Fvx' = 304.75 psi  (CSI = 0.49)   ➜  OK
fv = = 174.58 psi
 fv = 174.58 psi < Fvx' = 304.75 psi  (CSI = 0.57)   ➜  OK
5/28/2024 5
ΔLL = = 0.43 in.
(L/d)LL = 159.00 / 0.43 = 371
 ΔLL = 0.43 in = L/371 < L/360   ➜  OK
ΔTL = = 0.56 in.
(L/d)TL = 159.00 / 0.56 = 282
 ΔTL = 0.56 in = L/282 < L/240   ➜  OK
fc⊥ = = 474.3 psi
 fc⊥ = 474.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.73)   ➜  OK
5/28/2024 6
