Beam Design - 244
Size: 3.125 x 18
Selfweight: 155.0 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 158.3 lbs
Beam Design 2024A209
5/17/2024 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
5/17/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (141.00 + 3)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 1 x [56.25 x 141.00] x (12 in./ft.)3 = 4.59 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.69 = 158.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.59 = 155.0 lbs
Distributed Self Weight (ws) = = 13.19 plf
  ws = 13.19 plf
1129.13 lbs
1129.13 lbs
5/17/2024 3
fb = = 230.9 psi
 fb = 230.9 psi < Fbx' = 2760.0 psi  (CSI = 0.08)   ➜  OK
5/17/2024 4
fv* = = 21.96 psi
 fv* = 21.96 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
fv = = 29.48 psi
 fv = 29.48 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
5/17/2024 5
ΔLL = = 0.02 in.
(L/d)LL = 141.00 / 0.02 = 8988
 ΔLL = 0.02 in = L/8988 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 141.00 / 0.03 = 4776
 ΔTL = 0.03 in = L/4776 < L/240   ➜  OK
fc⊥ = = 120.4 psi
 fc⊥ = 120.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.19)   ➜  OK
5/17/2024 6
