Grade: DF SS
Design Span (L): 15.50 ft.
Clear Span: 15.00 ft.
Total Span: 16.00 ft.
Live Load: 275 plf
Selfweight: 193.3 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 199.5 lbs
Beam Design 2024A204
5/13/2024 1
5/13/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (186.00 + 6)] x (12 in./ft.)3 = 5.63 ft3
Volumespan = N[A x L] = 3 x [16.88 x 186.00] x (12 in./ft.)3 = 5.45 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 5.63 = 199.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 5.45 = 193.3 lbs
275 plf
ws = 12.47 plf
15.50 ft.
15.00 ft.
2899.75 lbs
2899.75 lbs
5/13/2024 3
Fbx' = (1500)(1.15)(0.85)(1)(1)(1)(1)(1) = 1466.2 psi
fb = = 1376.1 psi
 fb = 1376.1 psi < Fbx' = 1466.2 psi  (CSI = 0.94)   ➜  OK
5/13/2024 4
fv* = = 73.17 psi
 fv* = 73.17 psi < Fvx' = 200.79 psi  (CSI = 0.36)   ➜  OK
fv = = 83.23 psi
 fv = 83.23 psi < Fvx' = 200.79 psi  (CSI = 0.41)   ➜  OK
5/13/2024 5
ΔLL = = 0.39 in.
(L/d)LL = 186.00 / 0.39 = 476
 ΔLL = 0.39 in = L/476 < L/360   ➜  OK
ΔTL = = 0.52 in.
(L/d)TL = 186.00 / 0.52 = 361
 ΔTL = 0.52 in = L/361 < L/240   ➜  OK
fc⊥ = = 107.4 psi
 fc⊥ = 107.4 psi < Fc⊥x' = 418.75 psi  (CSI = 0.26)   ➜  OK
5/13/2024 6
