Grade: DF SS
Design Span (L): 15.50 ft.
Clear Span: 15.00 ft.
Total Span: 16.00 ft.
Live Load: 165 plf
Dead Load: 45 plf
Selfweight: 124.3 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 128.3 lbs
Beam Design 2024A202
5/13/2024 1
5/13/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (186.00 + 6)] x (12 in./ft.)3 = 3.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 186.00] x (12 in./ft.)3 = 3.63 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.75 = 128.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.63 = 124.3 lbs
165 plf
45 plf
ws = 8.02 plf
15.50 ft.
15.00 ft.
1744.13 lbs
1744.13 lbs
5/13/2024 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 1241.6 psi
 fb = 1241.6 psi < Fbx' = 1725.0 psi  (CSI = 0.72)   ➜  OK
5/13/2024 4
fv* = = 66.01 psi
 fv* = 66.01 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
fv = = 75.09 psi
 fv = 75.09 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
5/13/2024 5
ΔLL = = 0.32 in.
(L/d)LL = 186.00 / 0.32 = 587
 ΔLL = 0.32 in = L/587 < L/180   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 186.00 / 0.42 = 444
 ΔTL = 0.42 in = L/444 < L/120   ➜  OK
fc⊥ = = 96.9 psi
 fc⊥ = 96.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
5/13/2024 6
