Design Span (L): 9.00 ft.
Clear Span: 8.75 ft.
Total Span: 9.25 ft.
Selfweight: 118.1 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 121.4 lbs
Beam Design 2024A2
1/5/2024 1
Beam Design 2024A2
1/5/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (108.00 + 3)] x (12 in./ft.)3 = 3.25 ft3
Volumespan = N[A x L] = 3 x [16.88 x 108.00] x (12 in./ft.)3 = 3.16 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.25 = 121.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.16 = 118.1 lbs
ws = 13.12 plf
9.00 ft.
8.75 ft.
9.25 ft.
870.07 lbs
870.07 lbs
Beam Design 2024A2
1/5/2024 3
lu/d = = 2.13
Rb = = 5.24
 Rb = 5.24 < 50   ➜  OK
Beam Design 2024A2
1/5/2024 4
FbE = = 22281.55 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.00)(1)(1)(1)(1)(1) = 750.00 psi
CL =   = 0.998
Fbx' = (750)(1.00)(1)(1)(0.998)(1)(1)(1) = 748.7 psi
fb = = 240.8 psi
 fb = 240.8 psi < Fbx' = 748.7 psi  (CSI = 0.32)   ➜  OK
fv* = = 19.86 psi
 fv* = 19.86 psi < Fvx' = 175.00 psi  (CSI = 0.11)   ➜  OK
fv = = 25.08 psi
 fv = 25.08 psi < Fvx' = 175.00 psi  (CSI = 0.14)   ➜  OK
Beam Design 2024A2
1/5/2024 5
ΔLL = = 0.02 in.
(L/d)LL = 108.00 / 0.02 = 5469
 ΔLL = 0.02 in = L/5469 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 108.00 / 0.04 = 2907
 ΔTL = 0.04 in = L/2907 < L/240   ➜  OK
fc⊥ = = 64.4 psi
 fc⊥ = 64.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 2024A2
1/5/2024 6
