Grade: SP No.1
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Quantity (N): 4
Live Load: 480 plf
Dead Load: 180 plf
Selfweight: 194.4 lbs
Dist. Selfweight: 18.09 plf
Total Weight: 198.9 lbs
Beam Design 2024A198
5/13/2024 1
5/13/2024 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (129.00 + 3)] x (12 in./ft.)3 = 5.16 ft3
Volumespan = N[A x L] = 4 x [16.88 x 129.00] x (12 in./ft.)3 = 5.04 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 5.16 = 198.9 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 5.04 = 194.4 lbs
Distributed Self Weight (ws) = = 18.09 plf
480 plf
180 plf
ws = 18.09 plf
10.75 ft.
10.50 ft.
11.00 ft.
3729.47 lbs
3729.47 lbs
5/13/2024 3
fb = = 928.7 psi
 fb = 928.7 psi < Fbx' = 1000.0 psi  (CSI = 0.93)   ➜  OK
5/13/2024 4
fv* = = 66.87 psi
 fv* = 66.87 psi < Fvx' = 169.75 psi  (CSI = 0.39)   ➜  OK
fv = = 80.99 psi
 fv = 80.99 psi < Fvx' = 169.75 psi  (CSI = 0.48)   ➜  OK
5/13/2024 5
ΔLL = = 0.14 in.
(L/d)LL = 129.00 / 0.14 = 917
 ΔLL = 0.14 in = L/917 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 129.00 / 0.20 = 649
 ΔTL = 0.20 in = L/649 < L/240   ➜  OK
fc⊥ = = 207.2 psi
 fc⊥ = 207.2 psi < Fc⊥x' = 378.55 psi  (CSI = 0.55)   ➜  OK
5/13/2024 6
