Beam Design - Kim
Grade: SP DSS
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Quantity (N): 4
Live Load: 480 plf
Dead Load: 180 plf
Selfweight: 158.2 lbs
Dist. Selfweight: 18.09 plf
Total Weight: 162.8 lbs
Beam Design 2024A189
5/10/2024 1
5/10/2024 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (105.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 4 x [16.88 x 105.00] x (12 in./ft.)3 = 4.10 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 4.22 = 162.8 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 4.10 = 158.2 lbs
Distributed Self Weight (ws) = = 18.09 plf
480 plf
180 plf
ws = 18.09 plf
8.75 ft.
8.50 ft.
9.00 ft.
3051.38 lbs
3051.38 lbs
5/10/2024 3
Fbx' = (1800)(1.15)(0.85)(1)(1)(1)(1)(1) = 1759.5 psi
fb = = 615.3 psi
 fb = 615.3 psi < Fbx' = 1759.5 psi  (CSI = 0.35)   ➜  OK
5/10/2024 4
fv* = = 51.80 psi
 fv* = 51.80 psi < Fvx' = 195.21 psi  (CSI = 0.27)   ➜  OK
fv = = 65.92 psi
 fv = 65.92 psi < Fvx' = 195.21 psi  (CSI = 0.34)   ➜  OK
5/10/2024 5
ΔLL = = 0.05 in.
(L/d)LL = 105.00 / 0.05 = 2019
 ΔLL = 0.05 in = L/2019 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 105.00 / 0.07 = 1429
 ΔTL = 0.07 in = L/1429 < L/240   ➜  OK
Fc⊥x' = (660)(0.67)(1)(1) = 442.20 psi
fc⊥ = = 169.5 psi
 fc⊥ = 169.5 psi < Fc⊥x' = 442.20 psi  (CSI = 0.38)   ➜  OK
5/10/2024 6
