Beam Design - Kim
Grade: SP DSS
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Quantity (N): 4
Live Load: 480 plf
Dead Load: 180 plf
Selfweight: 153.1 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 157.5 lbs
Beam Design 2024A182
5/10/2024 1
5/10/2024 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (105.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 4 x [16.88 x 105.00] x (12 in./ft.)3 = 4.10 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.22 = 157.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.10 = 153.1 lbs
Distributed Self Weight (ws) = = 17.50 plf
480 plf
180 plf
ws = 17.50 plf
8.75 ft.
8.50 ft.
9.00 ft.
3048.74 lbs
3048.74 lbs
5/10/2024 3
fb = = 614.8 psi
 fb = 614.8 psi < Fbx' = 2070.0 psi  (CSI = 0.30)   ➜  OK
5/10/2024 4
fv* = = 51.75 psi
 fv* = 51.75 psi < Fvx' = 201.25 psi  (CSI = 0.26)   ➜  OK
fv = = 65.87 psi
 fv = 65.87 psi < Fvx' = 201.25 psi  (CSI = 0.33)   ➜  OK
5/10/2024 5
ΔLL = = 0.05 in.
(L/d)LL = 105.00 / 0.05 = 2243
 ΔLL = 0.05 in = L/2243 < L/180   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 105.00 / 0.07 = 1589
 ΔTL = 0.07 in = L/1589 < L/120   ➜  OK
fc⊥ = = 169.4 psi
 fc⊥ = 169.4 psi < Fc⊥x' = 660.00 psi  (CSI = 0.26)   ➜  OK
5/10/2024 6
