Beam Design - Rec Center
Size: 12.25 x 60
Design Span (L): 111.00 ft.
Clear Span: 109.00 ft.
Total Span: 113.00 ft.
Bearing (lb): 24 in.
Live Load: 750 plf
Dead Load: 350 plf
Selfweight: 38255.7 lbs
Dist. Selfweight: 344.65 plf
Total Weight: 38944.9 lbs
CV Volume Factor 0.661b - - - - -
Beam Design PoCo
1/12/2024 1
b = 12.250 in.
d = 60.000 in.
A = 12.250 x 60.000 = 735.00 in.2
Sx = (12.250)(60.000)2/6 = 7350.00 in.3
Sy = (12.250)2(60.000)/6 = 1500.63 in.3
Ix = (12.250)(60.000)3/12 = 220500.00 in.4
Iy = (12.250)3(60.000)/12 = 9191.33 in.4
Beam Design PoCo
1/12/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [735.00 x (1332.00 + 24)] x (12 in./ft.)3 = 1153.54 ft3
Volumespan = N[A x L] = 2 x [735.00 x 1332.00] x (12 in./ft.)3 = 1133.13 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1153.54 = 38944.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1133.13 = 38255.7 lbs
Distributed Self Weight (ws) = = 344.65 plf
750 plf
350 plf
  ws = 344.65 plf
111.00 ft.
109.00 ft.
113.00 ft.
81622.47 lbs
81622.47 lbs
Beam Design PoCo
1/12/2024 3
CV = = 0.661
CV = 0.661 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.661) = 1823.3 psi
fb = = 1816.3 psi
 fb = 1816.3 psi < Fbx' = 1823.3 psi  (CSI = 1.00)   ➜  OK
Beam Design PoCo
1/12/2024 4
fv* = = 74.44 psi
 fv* = 74.44 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
fv = = 81.81 psi
 fv = 81.81 psi < Fvx' = 304.75 psi  (CSI = 0.27)   ➜  OK
Beam Design PoCo
1/12/2024 5
ΔLL = = 3.23 in.
(L/d)LL = 1332.00 / 3.23 = 413
 ΔLL = 3.23 in = L/413 < L/180   ➜  OK
ΔTL = = 6.22 in.
(L/d)TL = 1332.00 / 6.22 = 214
 ΔTL = 6.22 in = L/214 < L/120   ➜  OK
Ab = b x lb = 12.25 x 24 = 294.00 in2
fc⊥ = = 138.8 psi
 fc⊥ = 138.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.21)   ➜  OK
Beam Design PoCo
1/12/2024 6
