Species: Hem-Fir
Grade: HF No.2
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 535.5 plf
Dead Load: 125.8 plf
Selfweight: 54.0 lbs
Dist. Selfweight: 6.97 plf
Total Weight: 55.8 lbs
Beam Design LESTER 2024A173
5/2/2024 1
G = 0.43
5/2/2024 2
= 29.74 lbs/ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 1.88 = 55.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 1.82 = 54.0 lbs
Distributed Self Weight (ws) = = 6.97 plf
535.5 plf
125.8 plf
ws = 6.97 plf
7.75 ft.
7.50 ft.
2673.08 lbs
2673.08 lbs
5/2/2024 3
Fbx' = (850)(1.15)(1)(1)(1)(1)(1)(1) = 977.5 psi
fb = = 951.4 psi
 fb = 951.4 psi < Fbx' = 977.5 psi  (CSI = 0.97)   ➜  OK
5/2/2024 4
Fvx' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 87.25 psi
 fv* = 87.25 psi < Fvx' = 172.50 psi  (CSI = 0.51)   ➜  OK
fv = = 115.09 psi
 fv = 115.09 psi < Fvx' = 172.50 psi  (CSI = 0.67)   ➜  OK
5/2/2024 5
ΔLL = = 0.09 in.
(L/d)LL = 93.00 / 0.09 = 990
 ΔLL = 0.09 in = L/990 < L/180   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 93.00 / 0.12 = 793
 ΔTL = 0.12 in = L/793 < L/120   ➜  OK
fc⊥ = = 297.0 psi
 fc⊥ = 297.0 psi < Fc⊥x' = 405.00 psi  (CSI = 0.73)   ➜  OK
5/2/2024 6
