Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 11
Design Span (L): 20.00 ft.
Clear Span: 19.83 ft.
Total Span: 20.17 ft.
Bearing (lb): 2 in.
Selfweight: 197.3 lbs
Dist. Selfweight: 9.86 plf
Total Weight: 198.9 lbs
Load Duration: 1.25
Beam Design 2024A170
4/30/2024 1
d = 11.000 in.
A = 3.500 x 11.000 = 38.50 in.2
Sx = (3.500)(11.000)2/6 = 70.58 in.3
Sy = (3.500)2(11.000)/6 = 22.46 in.3
Ix = (3.500)(11.000)3/12 = 388.21 in.4
Iy = (3.500)3(11.000)/12 = 39.30 in.4
4/30/2024 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [38.50 x (240.00 + 2)] x (12 in./ft.)3 = 5.39 ft3
Volumespan = N[A x L] = 1 x [38.50 x 240.00] x (12 in./ft.)3 = 5.35 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 5.39 = 198.9 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 5.35 = 197.3 lbs
Distributed Self Weight (ws) = = 9.86 plf
  ws = 9.86 plf
19.83 ft.
20.17 ft.
1864.03 lbs
1864.03 lbs
4/30/2024 3
Fbx' = (2400)(1.25)(1)(1)(1.0) = 3000.0 psi
fb = = 1571.4 psi
 fb = 1571.4 psi < Fbx' = 3000.0 psi  (CSI = 0.52)   ➜  OK
4/30/2024 4
Fvx' = (300)(1.25)(1)(1) = 375.00 psi
fv* = = 65.42 psi
 fv* = 65.42 psi < Fvx' = 375.00 psi  (CSI = 0.17)   ➜  OK
fv = = 72.02 psi
 fv = 72.02 psi < Fvx' = 375.00 psi  (CSI = 0.19)   ➜  OK
4/30/2024 5
ΔLL = = 0.52 in.
(L/d)LL = 240.00 / 0.52 = 466
 ΔLL = 0.52 in = L/466 < L/240   ➜  OK
ΔTL = = 0.95 in.
(L/d)TL = 240.00 / 0.95 = 252
 ΔTL = 0.95 in = L/252 < L/180   ➜  OK
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 266.3 psi
 fc⊥ = 266.3 psi < Fc⊥x' = 740.00 psi  (CSI = 0.36)   ➜  OK
4/30/2024 6
