Grade: DF No.1
Size: 4 x 14
Design Span (L): 10.00 ft.
Clear Span: 9.75 ft.
Total Span: 10.25 ft.
Live Load: 200 plf
Dead Load: 296 plf
Selfweight: 110.2 lbs
Dist. Selfweight: 11.02 plf
Total Weight: 112.9 lbs
Beam Design 2024A160
4/17/2024 1
d = 13.250 in.
4/17/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (120.00 + 3)] x (12 in./ft.)3 = 3.30 ft3
Volumespan = N[A x L] = 1 x [46.38 x 120.00] x (12 in./ft.)3 = 3.22 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.30 = 112.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.22 = 110.2 lbs
Distributed Self Weight (ws) = = 11.02 plf
200 plf
296 plf
ws = 11.02 plf
10.00 ft.
9.75 ft.
10.25 ft.
2598.45 lbs
2598.45 lbs
4/17/2024 3
lu/d = = 1.81
Rb = = 7.31
 Rb = 7.31 < 50   ➜  OK
4/17/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(0.9)(1) = 558000 psi
FbE = = 12521.52 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(0.8)(1)(1)(1) = 800.00 psi
CL =   = 0.997
Fbx' = (1000)(1.00)(1)(0.8)(0.997)(1)(1)(1) = 797.3 psi
fb = = 742.6 psi
 fb = 742.6 psi < Fbx' = 797.3 psi  (CSI = 0.93)   ➜  OK
Fvx' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 63.89 psi
 fv* = 63.89 psi < Fvx' = 144.00 psi  (CSI = 0.44)   ➜  OK
fv = = 82.00 psi
 fv = 82.00 psi < Fvx' = 144.00 psi  (CSI = 0.57)   ➜  OK
4/17/2024 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(0.9)(1) = 1530000 psi
ΔLL = = 0.04 in.
(L/d)LL = 120.00 / 0.04 = 2768
 ΔLL = 0.04 in = L/2768 < L/240   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 120.00 / 0.11 = 1092
 ΔTL = 0.11 in = L/1092 < L/180   ➜  OK
fc⊥ = = 247.5 psi
 fc⊥ = 247.5 psi < Fc⊥x' = 500.00 psi  (CSI = 0.49)   ➜  OK
4/17/2024 6
