Grade: DF No.1
Size: 4 x 16
Design Span (L): 15.00 ft.
Clear Span: 14.75 ft.
Total Span: 15.25 ft.
Live Load: 200 plf
Dead Load: 296 plf
Selfweight: 187.1 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 190.2 lbs
Beam Design 2024A157
4/17/2024 1
d = 15.000 in.
4/17/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (180.00 + 3)] x (12 in./ft.)3 = 5.56 ft3
Volumespan = N[A x L] = 1 x [52.50 x 180.00] x (12 in./ft.)3 = 5.47 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.56 = 190.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.47 = 187.1 lbs
200 plf
296 plf
ws = 12.47 plf
15.00 ft.
14.75 ft.
15.25 ft.
3877.08 lbs
3877.08 lbs
4/17/2024 3
Fbx' = (1000)(1.00)(1)(0.8)(1)(1)(1)(1) = 800.0 psi
fb = = 1307.5 psi
 fb = 1307.5 psi > Fbx' = 800.0 psi  (CSI = 1.63)   ➜  NG
4/17/2024 4
Fvx' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 90.80 psi
 fv* = 90.80 psi < Fvx' = 144.00 psi  (CSI = 0.63)   ➜  OK
fv = = 108.96 psi
 fv = 108.96 psi < Fvx' = 144.00 psi  (CSI = 0.76)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(0.9)(1) = 1530000 psi
4/17/2024 5
ΔLL = = 0.15 in.
(L/d)LL = 180.00 / 0.15 = 1190
 ΔLL = 0.15 in = L/1190 < L/180   ➜  OK
ΔTL = = 0.38 in.
(L/d)TL = 180.00 / 0.38 = 468
 ΔTL = 0.38 in = L/468 < L/120   ➜  OK
fc⊥ = = 369.2 psi
 fc⊥ = 369.2 psi < Fc⊥x' = 500.00 psi  (CSI = 0.74)   ➜  OK
4/17/2024 6
