Grade: DF No.1
Size: 4 x 16
Design Span (L): 10.00 ft.
Clear Span: 9.75 ft.
Total Span: 10.25 ft.
Live Load: 200 plf
Dead Load: 296 plf
Selfweight: 124.7 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 127.8 lbs
Beam Design 2024A155
4/17/2024 1
d = 15.000 in.
4/17/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (120.00 + 3)] x (12 in./ft.)3 = 3.74 ft3
Volumespan = N[A x L] = 1 x [52.50 x 120.00] x (12 in./ft.)3 = 3.65 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.74 = 127.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.65 = 124.7 lbs
200 plf
296 plf
ws = 12.47 plf
10.00 ft.
9.75 ft.
10.25 ft.
2605.91 lbs
2605.91 lbs
4/17/2024 3
lu/d = = 1.60
Rb = = 7.78
 Rb = 7.78 < 50   ➜  OK
4/17/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(0.9)(1) = 558000 psi
FbE = = 11060.68 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(0.8)(1)(1)(1.15) = 920.00 psi
CL =   = 0.996
Fbx' = (1000)(1.00)(1)(0.8)(0.996)(1)(1)(1.15) = 915.9 psi
fb = = 581.1 psi
 fb = 581.1 psi < Fbx' = 915.9 psi  (CSI = 0.63)   ➜  OK
Fvx' = (180)(1.00)(1)(0.8)(1) = 144.00 psi
fv* = = 54.48 psi
 fv* = 54.48 psi < Fvx' = 144.00 psi  (CSI = 0.38)   ➜  OK
fv = = 72.64 psi
 fv = 72.64 psi < Fvx' = 144.00 psi  (CSI = 0.50)   ➜  OK
4/17/2024 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(1)(0.9)(1) = 1530000 psi
ΔLL = = 0.03 in.
(L/d)LL = 120.00 / 0.03 = 4016
 ΔLL = 0.03 in = L/4016 < L/180   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 120.00 / 0.08 = 1580
 ΔTL = 0.08 in = L/1580 < L/120   ➜  OK
fc⊥ = = 248.2 psi
 fc⊥ = 248.2 psi < Fc⊥x' = 500.00 psi  (CSI = 0.50)   ➜  OK
4/17/2024 6
