Design Span (L): 12.00 ft.
Clear Span: 11.75 ft.
Total Span: 12.25 ft.
Live Load: 150 plf
Dead Load: 112.5 plf
Selfweight: 118.6 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 121.1 lbs
Beam Design 2024A153
4/11/2024 1
4/11/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (144.00 + 3)] x (12 in./ft.)3 = 3.54 ft3
Volumespan = N[A x L] = 3 x [13.88 x 144.00] x (12 in./ft.)3 = 3.47 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.54 = 121.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.47 = 118.6 lbs
150 plf
112.5 plf
ws = 9.89 plf
12.25 ft.
1668.37 lbs
1668.37 lbs
4/11/2024 3
fb = = 916.8 psi
 fb = 916.8 psi < Fbx' = 1138.5 psi  (CSI = 0.81)   ➜  OK
4/11/2024 4
fv* = = 51.33 psi
 fv* = 51.33 psi < Fvx' = 207.00 psi  (CSI = 0.25)   ➜  OK
fv = = 58.89 psi
 fv = 58.89 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
4/11/2024 5
ΔLL = = 0.15 in.
(L/d)LL = 144.00 / 0.15 = 977
 ΔLL = 0.15 in = L/977 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 144.00 / 0.27 = 538
 ΔTL = 0.27 in = L/538 < L/240   ➜  OK
fc⊥ = = 123.6 psi
 fc⊥ = 123.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
4/11/2024 6
