Design Span (L): 12.00 ft.
Clear Span: 11.75 ft.
Total Span: 12.25 ft.
Live Load: 150 plf
Dead Load: 112.5 plf
Selfweight: 96.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 98.2 lbs
Beam Design 2024A152
4/10/2024 1
4/10/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (144.00 + 3)] x (12 in./ft.)3 = 2.87 ft3
Volumespan = N[A x L] = 2 x [16.88 x 144.00] x (12 in./ft.)3 = 2.81 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.87 = 98.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.81 = 96.2 lbs
150 plf
112.5 plf
ws = 8.02 plf
12.25 ft.
1656.91 lbs
1656.91 lbs
4/10/2024 3
fb = = 923.4 psi
 fb = 923.4 psi < Fbx' = 1035.0 psi  (CSI = 0.89)   ➜  OK
4/10/2024 4
fv* = = 60.87 psi
 fv* = 60.87 psi < Fvx' = 207.00 psi  (CSI = 0.29)   ➜  OK
fv = = 72.14 psi
 fv = 72.14 psi < Fvx' = 207.00 psi  (CSI = 0.35)   ➜  OK
4/10/2024 5
ΔLL = = 0.12 in.
(L/d)LL = 144.00 / 0.12 = 1172
 ΔLL = 0.12 in = L/1172 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 144.00 / 0.22 = 650
 ΔTL = 0.22 in = L/650 < L/240   ➜  OK
fc⊥ = = 184.1 psi
 fc⊥ = 184.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.29)   ➜  OK
4/10/2024 6
