Beam Design - x
Grade: SP No.1
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 150 plf
Dead Load: 113 plf
Selfweight: 88.1 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 89.9 lbs
Notes: x
Beam Design x x x x
4/10/2024 1
Beam Design x x x x
4/10/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (147.00 + 3)] x (12 in./ft.)3 = 2.41 ft3
Volumespan = N[A x L] = 2 x [13.88 x 147.00] x (12 in./ft.)3 = 2.36 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.41 = 89.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.36 = 88.1 lbs
150 plf
113 plf
ws = 7.19 plf
12.25 ft.
12.50 ft.
1688.71 lbs
1688.71 lbs
Beam Design x x x x
4/10/2024 3
Fbx' = (1050)(1.15)(1)(1)(1)(1)(1)(1) = 1207.5 psi
fb = = 1421.6 psi
 fb = 1421.6 psi > Fbx' = 1207.5 psi  (CSI = 1.18)   ➜  NG
Beam Design x x x x
4/10/2024 4
fv* = = 78.20 psi
 fv* = 78.20 psi < Fvx' = 201.25 psi  (CSI = 0.39)   ➜  OK
fv = = 89.46 psi
 fv = 89.46 psi < Fvx' = 201.25 psi  (CSI = 0.44)   ➜  OK
Beam Design x x x x
4/10/2024 5
ΔLL = = 0.24 in.
(L/d)LL = 147.00 / 0.24 = 612
 ΔLL = 0.24 in = L/612 < L/360   ➜  OK
ΔTL = = 0.43 in.
(L/d)TL = 147.00 / 0.43 = 340
 ΔTL = 0.43 in = L/340 < L/240   ➜  OK
fc⊥ = = 187.6 psi
 fc⊥ = 187.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.33)   ➜  OK
Beam Design x x x x
4/10/2024 6
