Beam Design - 2024-1
Selfweight: 38.7 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 39.5 lbs
Beam Design r goodpaster 1
4/10/2024 1
4/10/2024 2
ws = 3.30 plf
1069.77 lbs
1069.77 lbs
4/10/2024 3
fb = = 1726.2 psi
4/10/2024 4
fv* = = 98.38 psi
fv = = 113.24 psi
4/10/2024 5
ΔLL = = 0.27 in.
(L/d)LL = 141.00 / 0.27 = 520
ΔTL = = 0.48 in.
(L/d)TL = 141.00 / 0.48 = 292
fc⊥ = = 237.7 psi
4/10/2024 6
