Beam Design - Kitchen Beam
Grade: 24F-V3 1.8E SP/SP
Size: 3 x 17.875
Design Span (L): 21.75 ft.
Clear Span: 21.50 ft.
Total Span: 22.00 ft.
Live Load: 125 plf
Selfweight: 298.8 lbs
Dist. Selfweight: 13.74 plf
Total Weight: 302.2 lbs
Defl. Limits: 480|360
Temperature: 125°F < T <= 150°F
Ct Temperature Factor 0.7 0.9 0.7 0.7 0.7 0.9
Beam Design Sos
4/5/2024 1
b = 3.000 in.
d = 17.875 in.
A = 3.000 x 17.875 = 53.63 in.2
Sx = (3.000)(17.875)2/6 = 159.76 in.3
Sy = (3.000)2(17.875)/6 = 26.81 in.3
Ix = (3.000)(17.875)3/12 = 1427.84 in.4
Iy = (3.000)3(17.875)/12 = 40.22 in.4
Beam Design Sos
4/5/2024 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [53.63 x (261.00 + 3)] x (12 in./ft.)3 = 8.19 ft3
Volumespan = N[A x L] = 1 x [53.63 x 261.00] x (12 in./ft.)3 = 8.10 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 8.19 = 302.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 8.10 = 298.8 lbs
Distributed Self Weight (ws) = = 13.74 plf
125 plf
  ws = 13.74 plf
21.75 ft.
21.50 ft.
22.00 ft.
2351.11 lbs
2351.11 lbs
Beam Design Sos
4/5/2024 3
Fbx' = (2400)(1.15)(1)(0.7)(1.0) = 1932.0 psi
fb = = 949.4 psi
 fb = 949.4 psi < Fbx' = 1932.0 psi  (CSI = 0.49)   ➜  OK
Beam Design Sos
4/5/2024 4
Fvx' = (300)(1.15)(1)(0.7) = 241.50 psi
fv* = = 56.11 psi
 fv* = 56.11 psi < Fvx' = 241.50 psi  (CSI = 0.23)   ➜  OK
fv = = 65.02 psi
 fv = 65.02 psi < Fvx' = 241.50 psi  (CSI = 0.27)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
Beam Design Sos
4/5/2024 5
ΔLL = = 0.27 in.
(L/d)LL = 261.00 / 0.27 = 959
 ΔLL = 0.27 in = L/959 < L/480   ➜  OK
ΔTL = = 0.47 in.
(L/d)TL = 261.00 / 0.47 = 561
 ΔTL = 0.47 in = L/561 < L/360   ➜  OK
Fc⊥x' = (740)(1)(0.7) = 518.00 psi
Ab = b x lb = 3 x 3 = 9.00 in2
fc⊥ = = 261.2 psi
 fc⊥ = 261.2 psi < Fc⊥x' = 518.00 psi  (CSI = 0.50)   ➜  OK
Beam Design Sos
4/5/2024 6
