Design Span (L): 6.71 ft.
Clear Span: 6.42 ft.
Total Span: 7.00 ft.
Bearing (lb): 3.5 in.
Live Load: 1600 lbs
Dead Load: 109 lbs
Selfweight: 34.7 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 36.2 lbs
Load Duration: 1.25
Beam Design 2024A142
4/1/2024 1
4/1/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (80.50 + 3.5)] x (12 in./ft.)3 = 1.06 ft3
Volumespan = N[A x L] = 2 x [10.88 x 80.50] x (12 in./ft.)3 = 1.01 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.06 = 36.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.01 = 34.7 lbs
1600 lbs
109 lbs
ws = 5.17 plf
6.71 ft.
6.42 ft.
7.00 ft.
872.58 lbs
872.58 lbs
4/1/2024 3
lu/d = = 3.31
Rb = = 6.31
 Rb = 6.31 < 50   ➜  OK
4/1/2024 4
FbE = = 17475.73 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.25)(1)(1)(1.2)(1)(1) = 1350.00 psi
CL =   = 0.996
Fbx' = (900)(1.25)(1)(1)(0.996)(1.2)(1)(1) = 1344.4 psi
fb = = 1321.9 psi
 fb = 1321.9 psi < Fbx' = 1344.4 psi  (CSI = 0.98)   ➜  OK
fv* = = 59.91 psi
 fv* = 59.91 psi < Fvx' = 225.00 psi  (CSI = 0.27)   ➜  OK
fv = = 60.13 psi
 fv = 60.13 psi < Fvx' = 225.00 psi  (CSI = 0.27)   ➜  OK
4/1/2024 5
ΔLL =   =   = 0.11 in.
(L/d)LL = 80.50 / 0.11 = 706
 ΔLL = 0.11 in = L/706 < L/360   ➜  OK
ΔTL =   =   = 0.12 in.
(L/d)TL = 80.50 / 0.12 = 652
 ΔTL = 0.12 in = L/652 < L/240   ➜  OK
fc⊥ = = 83.1 psi
 fc⊥ = 83.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
4/1/2024 6
