Size: 12.25 x 60
Design Span (L): 102.00 ft.
Clear Span: 100.00 ft.
Total Span: 104.00 ft.
Bearing (lb): 24 in.
Live Load: 750 plf
Dead Load: 350 plf
Selfweight: 35153.8 lbs
Dist. Selfweight: 344.65 plf
Total Weight: 35843.1 lbs
CV Volume Factor 0.666b - - - - -
Beam Design 2024A14
1/12/2024 1
b = 12.250 in.
d = 60.000 in.
A = 12.250 x 60.000 = 735.00 in.2
Sx = (12.250)(60.000)2/6 = 7350.00 in.3
Sy = (12.250)2(60.000)/6 = 1500.63 in.3
Ix = (12.250)(60.000)3/12 = 220500.00 in.4
Iy = (12.250)3(60.000)/12 = 9191.33 in.4
Beam Design 2024A14
1/12/2024 2
Volumetotal = N[A x (L + lb)] = 2 x [735.00 x (1224.00 + 24)] x (12 in./ft.)3 = 1061.67 ft3
Volumespan = N[A x L] = 2 x [735.00 x 1224.00] x (12 in./ft.)3 = 1041.25 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1061.67 = 35843.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1041.25 = 35153.8 lbs
Distributed Self Weight (ws) = = 344.65 plf
750 plf
350 plf
  ws = 344.65 plf
102.00 ft.
100.00 ft.
104.00 ft.
75121.57 lbs
75121.57 lbs
Beam Design 2024A14
1/12/2024 3
CV = = 0.666
CV = 0.666 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.666) = 1838.8 psi
fb = = 1533.7 psi
 fb = 1533.7 psi < Fbx' = 1838.8 psi  (CSI = 0.83)   ➜  OK
Beam Design 2024A14
1/12/2024 4
fv* = = 67.81 psi
 fv* = 67.81 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 75.18 psi
 fv = 75.18 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
Beam Design 2024A14
1/12/2024 5
ΔLL = = 2.30 in.
(L/d)LL = 1224.00 / 2.30 = 532
 ΔLL = 2.30 in = L/532 < L/180   ➜  OK
ΔTL = = 4.43 in.
(L/d)TL = 1224.00 / 4.43 = 276
 ΔTL = 4.43 in = L/276 < L/120   ➜  OK
Ab = b x lb = 12.25 x 24 = 294.00 in2
fc⊥ = = 127.8 psi
 fc⊥ = 127.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 2024A14
1/12/2024 6
