Beam Design - Deck Cover Truss Beam
Size: 5.5 x 18
Design Span (L): 25.25 ft.
Clear Span: 25.00 ft.
Total Span: 25.50 ft.
Live Load: 200 plf
Dead Load: 100 plf
Selfweight: 586.1 lbs
Dist. Selfweight: 23.21 plf
Total Weight: 591.9 lbs
CV Volume Factor 0.936b - - - - -
Beam Design Clayton Crites 1325 SW Panorama Dr. Pano
4/1/2024 1
d = 18.000 in.
4/1/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [99.00 x (303.00 + 3)] x (12 in./ft.)3 = 17.53 ft3
Volumespan = N[A x L] = 1 x [99.00 x 303.00] x (12 in./ft.)3 = 17.36 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.53 = 591.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.36 = 586.1 lbs
200 plf
  ws = 23.21 plf
25.25 ft.
25.00 ft.
25.50 ft.
4120.94 lbs
4120.94 lbs
4/1/2024 3
CV = = 0.936
CV = 0.936 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.936) = 2583.6 psi
fb = = 1040.7 psi
 fb = 1040.7 psi < Fbx' = 2583.6 psi  (CSI = 0.40)   ➜  OK
4/1/2024 4
fv* = = 54.48 psi
 fv* = 54.48 psi < Fvx' = 304.75 psi  (CSI = 0.18)   ➜  OK
fv = = 61.83 psi
 fv = 61.83 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
4/1/2024 5
ΔLL = = 0.38 in.
(L/d)LL = 303.00 / 0.38 = 797
 ΔLL = 0.38 in = L/797 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 303.00 / 0.61 = 493
 ΔTL = 0.61 in = L/493 < L/240   ➜  OK
fc⊥ = = 249.8 psi
 fc⊥ = 249.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.38)   ➜  OK
4/1/2024 6
