Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 350 plf
Dead Load: 280 plf
Selfweight: 33.7 lbs
Dist. Selfweight: 6.42 plf
Total Weight: 35.3 lbs
Beam Design 2024A135
3/29/2024 1
3/29/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [8.25 x (63.00 + 3)] x (12 in./ft.)3 = 0.95 ft3
Volumespan = N[A x L] = 3 x [8.25 x 63.00] x (12 in./ft.)3 = 0.90 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.95 = 35.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.90 = 33.7 lbs
Distributed Self Weight (ws) = = 6.42 plf
350 plf
280 plf
ws = 6.42 plf
5.25 ft.
5.00 ft.
5.50 ft.
1750.14 lbs
1750.14 lbs
3/29/2024 3
fb = = 1159.7 psi
 fb = 1159.7 psi > Fbx' = 1150.0 psi  (CSI = 1.01)   ➜  NG
3/29/2024 4
fv* = = 83.57 psi
 fv* = 83.57 psi < Fvx' = 201.25 psi  (CSI = 0.42)   ➜  OK
fv = = 101.25 psi
 fv = 101.25 psi < Fvx' = 201.25 psi  (CSI = 0.50)   ➜  OK
3/29/2024 5
ΔLL = = 0.07 in.
(L/d)LL = 63.00 / 0.07 = 920
 ΔLL = 0.07 in = L/920 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 63.00 / 0.12 = 506
 ΔTL = 0.12 in = L/506 < L/240   ➜  OK
fc⊥ = = 129.6 psi
 fc⊥ = 129.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.23)   ➜  OK
3/29/2024 6
