Grade: DF SS
Size: 4 x 10
Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Live Load: 160 plf
Dead Load: 40 plf
Selfweight: 123.0 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 125.0 lbs
CL Beam Stability Factor 0.947 - - - - -
Beam Design 2024A133
3/28/2024 1
3/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (192.00 + 3)] x (12 in./ft.)3 = 3.65 ft3
Volumespan = N[A x L] = 1 x [32.38 x 192.00] x (12 in./ft.)3 = 3.60 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.65 = 125.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.60 = 123.0 lbs
160 plf
40 plf
ws = 7.69 plf
15.75 ft.
16.25 ft.
1687.48 lbs
1687.48 lbs
3/28/2024 3
lu = Unbraced Length = 16 ft.
lu/d = = 20.76
le = 1.63lu + 3d = 1.63(192.0) + 3(9.25) = 340.71 in. = 28.39 ft.  (NDS Table 3.3.3)
Rb = = 16.04
 Rb = 16.04 < 50   ➜  OK
3/28/2024 4
FbE = = 3218.40 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.00)(1)(1)(1.2)(1)(1) = 1800.00 psi
CL =   = 0.947
Fbx' = (1500)(1.00)(1)(1)(0.947)(1.2)(1)(1) = 1704.1 psi
fb = = 1597.9 psi
 fb = 1597.9 psi < Fbx' = 1704.1 psi  (CSI = 0.94)   ➜  OK
fv* = = 69.56 psi
 fv* = 69.56 psi < Fvx' = 180.00 psi  (CSI = 0.39)   ➜  OK
fv = = 76.98 psi
 fv = 76.98 psi < Fvx' = 180.00 psi  (CSI = 0.43)   ➜  OK
3/28/2024 5
ΔLL = = 0.54 in.
(L/d)LL = 192.00 / 0.54 = 357
 ΔLL = 0.54 in = L/357 < L/180   ➜  OK
ΔTL = = 0.70 in.
(L/d)TL = 192.00 / 0.70 = 275
 ΔTL = 0.70 in = L/275 < L/120   ➜  OK
fc⊥ = = 160.7 psi
 fc⊥ = 160.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.26)   ➜  OK
3/28/2024 6
