Grade: DF No.1
Size: 4 x 6
Design Span (L): 8.00 ft.
Clear Span: 7.75 ft.
Total Span: 8.25 ft.
Live Load: 160 plf
Dead Load: 38 plf
Selfweight: 36.6 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 37.7 lbs
Beam Design 2024A128
3/28/2024 1
3/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (96.00 + 3)] x (12 in./ft.)3 = 1.10 ft3
Volumespan = N[A x L] = 1 x [19.25 x 96.00] x (12 in./ft.)3 = 1.07 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.10 = 37.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.07 = 36.6 lbs
160 plf
38 plf
ws = 4.57 plf
7.75 ft.
8.25 ft.
835.61 lbs
835.61 lbs
3/28/2024 3
lu/d = = 4.36
Rb = = 4.71
 Rb = 4.71 < 50   ➜  OK
3/28/2024 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(1)(1) = 620000 psi
FbE = = 33517.21 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.00)(1)(1)(1.3)(1)(1.15) = 1495.00 psi
CL =   = 0.998
Fbx' = (1000)(1.00)(1)(1)(0.998)(1.3)(1)(1.15) = 1491.5 psi
fb = = 1102.1 psi
 fb = 1102.1 psi < Fbx' = 1491.5 psi  (CSI = 0.74)   ➜  OK
fv* = = 55.90 psi
 fv* = 55.90 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
fv = = 63.14 psi
 fv = 63.14 psi < Fvx' = 180.00 psi  (CSI = 0.35)   ➜  OK
3/28/2024 5
ΔLL = = 0.18 in.
(L/d)LL = 96.00 / 0.18 = 537
 ΔLL = 0.18 in = L/537 < L/180   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 96.00 / 0.23 = 424
 ΔTL = 0.23 in = L/424 < L/120   ➜  OK
fc⊥ = = 79.6 psi
 fc⊥ = 79.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
3/28/2024 6
