Grade: DF SS
Size: 4 x 14
Design Span (L): 16.00 ft.
Clear Span: 15.75 ft.
Total Span: 16.25 ft.
Live Load: 320 plf
Dead Load: 76 plf
Selfweight: 176.2 lbs
Dist. Selfweight: 11.02 plf
Total Weight: 179.0 lbs
Beam Design 2024A127
3/28/2024 1
d = 13.250 in.
3/28/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [46.38 x (192.00 + 3)] x (12 in./ft.)3 = 5.23 ft3
Volumespan = N[A x L] = 1 x [46.38 x 192.00] x (12 in./ft.)3 = 5.15 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 5.23 = 179.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 5.15 = 176.2 lbs
Distributed Self Weight (ws) = = 11.02 plf
320 plf
76 plf
ws = 11.02 plf
15.75 ft.
16.25 ft.
3307.00 lbs
3307.00 lbs
3/28/2024 3
lu/d = = 1.81
Rb = = 7.31
 Rb = 7.31 < 50   ➜  OK
3/28/2024 4
FbE = = 15483.61 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.00)(1)(1)(1)(1)(1.15) = 1725.00 psi
CL =   = 0.994
Fbx' = (1500)(1.00)(1)(1)(0.994)(1)(1)(1.15) = 1714.3 psi
fb = = 1526.1 psi
 fb = 1526.1 psi < Fbx' = 1714.3 psi  (CSI = 0.89)   ➜  OK
fv* = = 90.78 psi
 fv* = 90.78 psi < Fvx' = 180.00 psi  (CSI = 0.50)   ➜  OK
fv = = 105.32 psi
 fv = 105.32 psi < Fvx' = 180.00 psi  (CSI = 0.59)   ➜  OK
3/28/2024 5
ΔLL = = 0.37 in.
(L/d)LL = 192.00 / 0.37 = 525
 ΔLL = 0.37 in = L/525 < L/180   ➜  OK
ΔTL = = 0.47 in.
(L/d)TL = 192.00 / 0.47 = 412
 ΔTL = 0.47 in = L/412 < L/120   ➜  OK
fc⊥ = = 315.0 psi
 fc⊥ = 315.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.50)   ➜  OK
3/28/2024 6
