Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 662 plf
Dead Load: 104 plf
Selfweight: 101.7 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 105.0 lbs
Beam Design GROSS 2024A125
3/28/2024 1
3/28/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (93.00 + 3)] x (12 in./ft.)3 = 2.81 ft3
Volumespan = N[A x L] = 3 x [16.88 x 93.00] x (12 in./ft.)3 = 2.72 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.81 = 105.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.72 = 101.7 lbs
662 plf
104 plf
ws = 13.12 plf
7.75 ft.
7.50 ft.
3116.50 lbs
3116.50 lbs
3/28/2024 3
fb = = 739.5 psi
 fb = 739.5 psi < Fbx' = 862.5 psi  (CSI = 0.86)   ➜  OK
3/28/2024 4
fv* = = 67.81 psi
 fv* = 67.81 psi < Fvx' = 201.25 psi  (CSI = 0.34)   ➜  OK
fv = = 89.45 psi
 fv = 89.45 psi < Fvx' = 201.25 psi  (CSI = 0.44)   ➜  OK
3/28/2024 5
ΔLL = = 0.07 in.
(L/d)LL = 93.00 / 0.07 = 1294
 ΔLL = 0.07 in = L/1294 < L/180   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 93.00 / 0.08 = 1099
 ΔTL = 0.08 in = L/1099 < L/120   ➜  OK
fc⊥ = = 230.9 psi
 fc⊥ = 230.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.41)   ➜  OK
3/28/2024 6
