Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 662 plf
Dead Load: 104 plf
Selfweight: 67.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Beam Design GROSS 2024A123
3/28/2024 1
3/28/2024 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.82 = 67.8 lbs
662 plf
104 plf
ws = 8.75 plf
7.75 ft.
7.50 ft.
3099.00 lbs
3099.00 lbs
3/28/2024 3
fb = = 1103.0 psi
 fb = 1103.0 psi > Fbx' = 862.5 psi  (CSI = 1.28)   ➜  NG
3/28/2024 4
fv* = = 101.15 psi
 fv* = 101.15 psi < Fvx' = 201.25 psi  (CSI = 0.50)   ➜  OK
fv = = 133.43 psi
 fv = 133.43 psi < Fvx' = 201.25 psi  (CSI = 0.66)   ➜  OK
3/28/2024 5
ΔLL = = 0.11 in.
(L/d)LL = 93.00 / 0.11 = 863
 ΔLL = 0.11 in = L/863 < L/180   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 93.00 / 0.13 = 737
 ΔTL = 0.13 in = L/737 < L/120   ➜  OK
fc⊥ = = 344.3 psi
 fc⊥ = 344.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.61)   ➜  OK
3/28/2024 6
