Grade: SPF No.2
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 80 plf
Dead Load: 35 plf
Selfweight: 79.3 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 81.8 lbs
Beam Design 2024A121
3/27/2024 1
3/27/2024 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (93.00 + 3)] x (12 in./ft.)3 = 2.81 ft3
Volumespan = N[A x L] = 3 x [16.88 x 93.00] x (12 in./ft.)3 = 2.72 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.81 = 81.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.72 = 79.3 lbs
Distributed Self Weight (ws) = = 10.23 plf
80 plf
35 plf
ws = 10.23 plf
7.75 ft.
7.50 ft.
500.92 lbs
500.92 lbs
3/27/2024 3
Fbx' = (875)(1.00)(1)(1)(1)(1)(1)(1) = 875.0 psi
fb = = 118.9 psi
 fb = 118.9 psi < Fbx' = 875.0 psi  (CSI = 0.14)   ➜  OK
3/27/2024 4
fv* = = 10.90 psi
 fv* = 10.90 psi < Fvx' = 135.00 psi  (CSI = 0.08)   ➜  OK
fv = = 14.38 psi
 fv = 14.38 psi < Fvx' = 135.00 psi  (CSI = 0.11)   ➜  OK
3/27/2024 5
ΔLL = = 0.01 in.
(L/d)LL = 93.00 / 0.01 = 10706
 ΔLL = 0.01 in = L/10706 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 93.00 / 0.01 = 6839
 ΔTL = 0.01 in = L/6839 < L/240   ➜  OK
fc⊥ = = 37.1 psi
 fc⊥ = 37.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.09)   ➜  OK
3/27/2024 6
