Size: 5.5 x 16.5
Design Span (L): 20.00 ft.
Clear Span: 19.75 ft.
Total Span: 20.25 ft.
Live Load: 300 plf
Dead Load: 50 plf
Selfweight: 425.5 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 430.9 lbs
CV Volume Factor 0.967b - - - - -
Beam Design 2024A120
3/26/2024 1
d = 16.500 in.
3/26/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (240.00 + 3)] x (12 in./ft.)3 = 12.76 ft3
Volumespan = N[A x L] = 1 x [90.75 x 240.00] x (12 in./ft.)3 = 12.60 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.76 = 430.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.60 = 425.5 lbs
300 plf
50 plf
  ws = 21.28 plf
19.75 ft.
20.25 ft.
3759.18 lbs
3759.18 lbs
3/26/2024 3
CV = = 0.967
CV = 0.967 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.967) = 2667.7 psi
fb = = 892.6 psi
 fb = 892.6 psi < Fbx' = 2667.7 psi  (CSI = 0.33)   ➜  OK
3/26/2024 4
fv* = = 52.93 psi
 fv* = 52.93 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
fv = = 61.37 psi
 fv = 61.37 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
3/26/2024 5
ΔLL = = 0.29 in.
(L/d)LL = 240.00 / 0.29 = 824
 ΔLL = 0.29 in = L/824 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 240.00 / 0.36 = 665
 ΔTL = 0.36 in = L/665 < L/240   ➜  OK
fc⊥ = = 227.8 psi
 fc⊥ = 227.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.35)   ➜  OK
3/26/2024 6
