Grade: SPF No.1
Size: 4 x 16
Design Span (L): 23.50 ft.
Clear Span: 23.00 ft.
Total Span: 24.00 ft.
Live Load: 48 plf
Dead Load: 180 plf
Selfweight: 249.3 lbs
Dist. Selfweight: 10.61 plf
Total Weight: 254.6 lbs
Incised Lumber: Yes
Beam Design 2024A113
3/24/2024 1
d = 15.000 in.
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
3/24/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (282.00 + 6)] x (12 in./ft.)3 = 8.75 ft3
Volumespan = N[A x L] = 1 x [52.50 x 282.00] x (12 in./ft.)3 = 8.57 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 8.75 = 254.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 8.57 = 249.3 lbs
Distributed Self Weight (ws) = = 10.61 plf
48 plf
180 plf
ws = 10.61 plf
23.50 ft.
23.00 ft.
24.00 ft.
2863.30 lbs
2863.30 lbs
3/24/2024 3
Fbx' = (875)(1.15)(1)(1)(1)(1)(0.8)(1) = 805.0 psi
fb = = 1506.0 psi
 fb = 1506.0 psi > Fbx' = 805.0 psi  (CSI = 1.87)   ➜  NG
3/24/2024 4
Fvx' = (135)(1.15)(1)(1)(0.8) = 124.20 psi
fv* = = 71.58 psi
 fv* = 71.58 psi < Fvx' = 124.20 psi  (CSI = 0.58)   ➜  OK
fv = = 80.10 psi
 fv = 80.10 psi < Fvx' = 124.20 psi  (CSI = 0.64)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(1)(1)(0.95) = 1330000 psi
3/24/2024 5
ΔLL = = 0.25 in.
(L/d)LL = 282.00 / 0.25 = 1121
 ΔLL = 0.25 in = L/1121 < L/360   ➜  OK
ΔTL = = 1.25 in.
(L/d)TL = 282.00 / 1.25 = 225
 ΔTL = 1.25 in = L/225 > L/240   ➜  NG
fc⊥ = = 136.3 psi
 fc⊥ = 136.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.32)   ➜  OK
3/24/2024 6
