Grade: SPF No.1
Size: 4 x 16
Design Span (L): 22.25 ft.
Clear Span: 21.75 ft.
Total Span: 22.75 ft.
Live Load: 480 plf
Dead Load: 190 plf
Selfweight: 236.0 lbs
Dist. Selfweight: 10.61 plf
Total Weight: 241.3 lbs
Incised Lumber: Yes
Beam Design Jim Russel 2024A109
3/24/2024 1
d = 15.000 in.
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
3/24/2024 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (267.00 + 6)] x (12 in./ft.)3 = 8.29 ft3
Volumespan = N[A x L] = 1 x [52.50 x 267.00] x (12 in./ft.)3 = 8.11 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 8.29 = 241.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 8.11 = 236.0 lbs
Distributed Self Weight (ws) = = 10.61 plf
480 plf
190 plf
ws = 10.61 plf
22.25 ft.
21.75 ft.
22.75 ft.
7741.92 lbs
7741.92 lbs
3/24/2024 3
Fbx' = (875)(1.15)(1)(1)(1)(1)(0.8)(1) = 805.0 psi
fb = = 3850.8 psi
 fb = 3850.8 psi > Fbx' = 805.0 psi  (CSI = 4.78)   ➜  NG
3/24/2024 4
Fvx' = (135)(1.15)(1)(1)(0.8) = 124.20 psi
fv* = = 192.03 psi
 fv* = 192.03 psi > Fvx' = 124.20 psi  (CSI = 1.55)   ➜  NG
fv = = 216.34 psi
 fv = 216.34 psi > Fvx' = 124.20 psi  (CSI = 1.74)   ➜  NG
Ex' = Ex(CM)(Ct)(Ci) = 1400000(1)(1)(0.95) = 1330000 psi
3/24/2024 5
ΔLL = = 2.02 in.
(L/d)LL = 267.00 / 2.02 = 132
 ΔLL = 2.02 in = L/132 > L/360   ➜  NG
ΔTL = = 2.87 in.
(L/d)TL = 267.00 / 2.87 = 93
 ΔTL = 2.87 in = L/93 > L/240   ➜  NG
fc⊥ = = 368.7 psi
 fc⊥ = 368.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.87)   ➜  OK
3/24/2024 6
