Size: 6.75 x 52.5
Design Span (L): 70.50 ft.
Clear Span: 69.00 ft.
Total Span: 72.00 ft.
Bearing (lb): 18 in.
Quantity (N): 5
Live Load: 2542 plf
Dead Load: 115 plf
Selfweight: 30767.1 lbs
Dist. Selfweight: 436.41 plf
Total Weight: 31421.7 lbs
Lateral Support: 8' o/c
CL Beam Stability Factor 0.999 - - - - -
CV Volume Factor 0.744b - - - - -
Beam Design 2024A104
3/14/2024 1
b = 6.750 in.
d = 52.500 in.
A = 6.750 x 52.500 = 354.38 in.2
Sx = (6.750)(52.500)2/6 = 3100.78 in.3
Sy = (6.750)2(52.500)/6 = 398.67 in.3
Ix = (6.750)(52.500)3/12 = 81395.51 in.4
Iy = (6.750)3(52.500)/12 = 1345.52 in.4
3/14/2024 2
Volumetotal = N[A x (L + lb)] = 5 x [354.38 x (846.00 + 18)] x (12 in./ft.)3 = 885.94 ft3
Volumespan = N[A x L] = 5 x [354.38 x 846.00] x (12 in./ft.)3 = 867.48 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 885.94 = 31421.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 867.48 = 30767.1 lbs
Distributed Self Weight (ws) = = 436.41 plf
2542 plf
115 plf
  ws = 436.41 plf
70.50 ft.
69.00 ft.
72.00 ft.
111362.83 lbs
111362.83 lbs
3/14/2024 3
lu = Unbraced Length = 8 ft.
lu/d = = 1.83
le = 2.06lu = 2.06(96.0) = 197.76 in. = 16.48 ft.  (NDS Table 3.3.3)
Rb = = 3.02
 Rb = 3.02 < 50   ➜  OK
3/14/2024 4
FbE = = 93216.97 psi
CL =   = 0.999
CV = = 0.744
CV = 0.744 < CL = 0.999
Fbx' = (2400)(1.15)(0.8)(1)(0.744) = 1641.9 psi
fb = = 1487.5 psi
 fb = 1487.5 psi < Fbx' = 1641.9 psi  (CSI = 0.91)   ➜  OK
fv* = = 80.85 psi
3/14/2024 5
 fv* = 80.85 psi < Fvx' = 266.66 psi  (CSI = 0.30)   ➜  OK
fv = = 92.31 psi
 fv = 92.31 psi < Fvx' = 266.66 psi  (CSI = 0.35)   ➜  OK
ΔLL = = 2.32 in.
(L/d)LL = 846.00 / 2.32 = 365
 ΔLL = 2.32 in = L/365 < L/360   ➜  OK
ΔTL = = 2.82 in.
(L/d)TL = 846.00 / 2.82 = 300
 ΔTL = 2.82 in = L/300 < L/240   ➜  OK
3/14/2024 6
Ab = b x lb = 6.75 x 18 = 121.50 in2
fc⊥ = = 183.3 psi
 fc⊥ = 183.3 psi < Fc⊥x' = 344.50 psi  (CSI = 0.53)   ➜  OK
3/14/2024 7
