Size: 6.75 x 54
Design Span (L): 70.50 ft.
Clear Span: 69.00 ft.
Total Span: 72.00 ft.
Bearing (lb): 18 in.
Quantity (N): 4
Live Load: 2542 plf
Dead Load: 115 plf
Selfweight: 25316.9 lbs
Dist. Selfweight: 359.10 plf
Total Weight: 25855.5 lbs
Lateral Support: 8' o/c
CV Volume Factor 0.742b - - - - -
Beam Design 2024A102
3/14/2024 1
b = 6.750 in.
d = 54.000 in.
A = 6.750 x 54.000 = 364.50 in.2
Sx = (6.750)(54.000)2/6 = 3280.50 in.3
Sy = (6.750)2(54.000)/6 = 410.06 in.3
Ix = (6.750)(54.000)3/12 = 88573.50 in.4
Iy = (6.750)3(54.000)/12 = 1383.96 in.4
3/14/2024 2
Volumetotal = N[A x (L + lb)] = 4 x [364.50 x (846.00 + 18)] x (12 in./ft.)3 = 729.00 ft3
Volumespan = N[A x L] = 4 x [364.50 x 846.00] x (12 in./ft.)3 = 713.81 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 729.00 = 25855.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 713.81 = 25316.9 lbs
Distributed Self Weight (ws) = = 359.10 plf
2542 plf
115 plf
  ws = 359.10 plf
70.50 ft.
69.00 ft.
72.00 ft.
108579.77 lbs
108579.77 lbs
3/14/2024 3
lu = Unbraced Length = 8 ft.
lu/d = = 1.78
le = 2.06lu = 2.06(96.0) = 197.76 in. = 16.48 ft.  (NDS Table 3.3.3)
Rb = = 3.83
 Rb = 3.83 < 50   ➜  OK
3/14/2024 4
FbE = = 58001.67 psi
CL =   = 0.998
CV = = 0.742
CV = 0.742 < CL = 0.998
Fbx' = (2400)(1.15)(0.8)(1)(0.742) = 1637.3 psi
fb = = 1713.6 psi
 fb = 1713.6 psi > Fbx' = 1637.3 psi  (CSI = 1.05)   ➜  NG
fv* = = 95.42 psi
3/14/2024 5
 fv* = 95.42 psi < Fvx' = 266.66 psi  (CSI = 0.36)   ➜  OK
fv = = 109.38 psi
 fv = 109.38 psi < Fvx' = 266.66 psi  (CSI = 0.41)   ➜  OK
ΔLL = = 2.66 in.
(L/d)LL = 846.00 / 2.66 = 318
 ΔLL = 2.66 in = L/318 > L/360   ➜  NG
ΔTL = = 3.16 in.
(L/d)TL = 846.00 / 3.16 = 268
 ΔTL = 3.16 in = L/268 < L/240   ➜  OK
3/14/2024 6
Ab = b x lb = 6.75 x 18 = 121.50 in2
fc⊥ = = 223.4 psi
 fc⊥ = 223.4 psi < Fc⊥x' = 344.50 psi  (CSI = 0.65)   ➜  OK
3/14/2024 7
