Beam Design - 14 x 16 Shed Beams
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 440 plf
Dead Load: 190 plf
Selfweight: 70.1 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 72.3 lbs
Incised Lumber: Yes
Beam Design D MCN Rich
1/12/2024 1
1/12/2024 2
= 38.58 lbs/ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.88 = 72.3 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.82 = 70.1 lbs
Distributed Self Weight (ws) = = 9.04 plf
440 plf
190 plf
ws = 9.04 plf
7.75 ft.
7.50 ft.
2556.17 lbs
2556.17 lbs
1/12/2024 3
Fbx' = (750)(1.15)(1)(1)(1)(1)(0.8)(1) = 690.0 psi
fb = = 909.8 psi
 fb = 909.8 psi > Fbx' = 690.0 psi  (CSI = 1.32)   ➜  NG
1/12/2024 4
Fvx' = (175)(1.15)(0.97)(1)(0.8) = 156.17 psi
fv* = = 83.43 psi
 fv* = 83.43 psi < Fvx' = 156.17 psi  (CSI = 0.53)   ➜  OK
fv = = 110.06 psi
 fv = 110.06 psi < Fvx' = 156.17 psi  (CSI = 0.70)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(0.9)(1)(0.95) = 1197000 psi
1/12/2024 5
ΔLL = = 0.08 in.
(L/d)LL = 93.00 / 0.08 = 1110
 ΔLL = 0.08 in = L/1110 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 93.00 / 0.12 = 764
 ΔTL = 0.12 in = L/764 < L/240   ➜  OK
fc⊥ = = 284.0 psi
 fc⊥ = 284.0 psi < Fc⊥x' = 378.55 psi  (CSI = 0.75)   ➜  OK
1/12/2024 6
