Grade: SPF SS
Design Span (L): 5.25 ft.
Clear Span: 5.00 ft.
Total Span: 5.50 ft.
Live Load: 1150 plf
Dead Load: 345 plf
Selfweight: 29.4 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 30.8 lbs
Beam Design 2023A99
3/23/2023 1
Beam Design 2023A99
3/23/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (63.00 + 3)] x (12 in./ft.)3 = 1.06 ft3
Volumespan = N[A x L] = 2 x [13.88 x 63.00] x (12 in./ft.)3 = 1.01 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.06 = 30.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.01 = 29.4 lbs
1150 plf
345 plf
ws = 5.61 plf
5.25 ft.
5.00 ft.
5.50 ft.
4126.67 lbs
4126.67 lbs
Beam Design 2023A99
3/23/2023 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(1)(1) = 1581.3 psi
fb = = 1450.2 psi
 fb = 1450.2 psi < Fbx' = 1581.3 psi  (CSI = 0.92)   ➜  OK
Beam Design 2023A99
3/23/2023 4
fv* = = 150.40 psi
 fv* = 150.40 psi < Fvx' = 155.25 psi  (CSI = 0.97)   ➜  OK
fv = = 212.92 psi
 fv = 212.92 psi > Fvx' = 155.25 psi  (CSI = 1.37)   ➜  NG
Beam Design 2023A99
3/23/2023 5
ΔLL = = 0.07 in.
(L/d)LL = 63.00 / 0.07 = 951
 ΔLL = 0.07 in = L/951 < L/180   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 63.00 / 0.09 = 729
 ΔTL = 0.09 in = L/729 < L/120   ➜  OK
fc⊥ = = 458.5 psi
 fc⊥ = 458.5 psi > Fc⊥x' = 425.00 psi  (CSI = 1.08)   ➜  NG
Beam Design 2023A99
3/23/2023 6
