Beam Design - Hillside Covenant Church
Size: 4 x 6
Live Load: 0 plf
Dead Load: 23.33 plf
Selfweight: 55.7 lbs
Dist. Selfweight: 4.74 plf
Total Weight: 56.9 lbs
Beam Design Ed Hultgren 1802 Whtiecliff Way 2023A89
3/17/2023 1
3/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (141.00 + 3)] x (12 in./ft.)3 = 1.60 ft3
Volumespan = N[A x L] = 1 x [19.25 x 141.00] x (12 in./ft.)3 = 1.57 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.60 = 56.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.57 = 55.7 lbs
Distributed Self Weight (ws) = = 4.74 plf
0 plf
23.33 plf
ws = 4.74 plf
168.43 lbs
168.43 lbs
3/17/2023 3
Fbx' = (900)(0.9)(0.85)(1)(1)(1.3)(1)(1) = 895.1 psi
fb = = 329.4 psi
 fb = 329.4 psi < Fbx' = 895.1 psi  (CSI = 0.37)   ➜  OK
3/17/2023 4
Fvx' = (180)(0.9)(0.97)(1)(1) = 157.14 psi
fv* = = 11.85 psi
 fv* = 11.85 psi < Fvx' = 157.14 psi  (CSI = 0.08)   ➜  OK
fv = = 12.85 psi
 fv = 12.85 psi < Fvx' = 157.14 psi  (CSI = 0.08)   ➜  OK
3/17/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 141.00 / 0.00 = ∞
ΔTL = = 0.17 in.
(L/d)TL = 141.00 / 0.17 = 818
 ΔTL = 0.17 in = L/818 < L/240   ➜  OK
fc⊥ = = 16.0 psi
 fc⊥ = 16.0 psi < Fc⊥x' = 418.75 psi  (CSI = 0.04)   ➜  OK
3/17/2023 6
