Beam Design - Hillside Covenant Church
Size: 4 x 4
Live Load: 0 plf
Dead Load: 30.89 plf
Selfweight: 35.5 lbs
Dist. Selfweight: 3.02 plf
Total Weight: 36.2 lbs
Beam Design Ed Hultgren 1802 Whtiecliff Way 2023A87
3/17/2023 1
d = 3.500 in.
3/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (141.00 + 3)] x (12 in./ft.)3 = 1.02 ft3
Volumespan = N[A x L] = 1 x [12.25 x 141.00] x (12 in./ft.)3 = 1.00 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 1.02 = 36.2 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 1.00 = 35.5 lbs
Distributed Self Weight (ws) = = 3.02 plf
0 plf
30.89 plf
ws = 3.02 plf
203.44 lbs
203.44 lbs
3/17/2023 3
Fbx' = (900)(0.9)(0.85)(1)(1)(1.5)(1)(1) = 1032.8 psi
fb = = 982.7 psi
 fb = 982.7 psi < Fbx' = 1032.8 psi  (CSI = 0.95)   ➜  OK
3/17/2023 4
Fvx' = (180)(0.9)(0.97)(1)(1) = 157.14 psi
fv* = = 23.18 psi
 fv* = 23.18 psi < Fvx' = 157.14 psi  (CSI = 0.15)   ➜  OK
fv = = 24.39 psi
 fv = 24.39 psi < Fvx' = 157.14 psi  (CSI = 0.16)   ➜  OK
3/17/2023 5
ΔLL = = 0.00 in.
(L/d)LL = 141.00 / 0.00 = ∞
ΔTL = = 0.81 in.
(L/d)TL = 141.00 / 0.81 = 175
 ΔTL = 0.81 in = L/175 > L/240   ➜  NG
fc⊥ = = 19.4 psi
 fc⊥ = 19.4 psi < Fc⊥x' = 418.75 psi  (CSI = 0.05)   ➜  OK
3/17/2023 6
