Design Span (L): 15.00 ft.
Clear Span: 14.00 ft.
Total Span: 16.00 ft.
Bearing (lb): 12 in.
Quantity (N): 4
Selfweight: 155.0 lbs
Dist. Selfweight: 10.33 plf
Total Weight: 165.3 lbs
Beam Design 2023A8
1/22/2023 1
Beam Design 2023A8
1/22/2023 2
Volumetotal = N[A x (L + lb)] = 4 x [10.88 x (180.00 + 12)] x (12 in./ft.)3 = 4.83 ft3
Volumespan = N[A x L] = 4 x [10.88 x 180.00] x (12 in./ft.)3 = 4.53 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.83 = 165.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.53 = 155.0 lbs
Distributed Self Weight (ws) = = 10.33 plf
ws = 10.33 plf
15.00 ft.
1482.66 lbs
1482.66 lbs
Beam Design 2023A8
1/22/2023 3
fb = = 1190.0 psi
 fb = 1190.0 psi < Fbx' = 1242.0 psi  (CSI = 0.96)   ➜  OK
Beam Design 2023A8
1/22/2023 4
fv* = = 44.07 psi
 fv* = 44.07 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
fv = = 47.93 psi
 fv = 47.93 psi < Fvx' = 207.00 psi  (CSI = 0.23)   ➜  OK
Beam Design 2023A8
1/22/2023 5
ΔLL = = 0.37 in.
(L/d)LL = 180.00 / 0.37 = 482
 ΔLL = 0.37 in = L/482 < L/360   ➜  OK
ΔTL = = 0.69 in.
(L/d)TL = 180.00 / 0.69 = 260
 ΔTL = 0.69 in = L/260 < L/240   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 20.6 psi
 fc⊥ = 20.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 2023A8
1/22/2023 6
