Beam Design - BAGS
Size: 10.75 x 37.5
Design Span (L): 49.33 ft.
Clear Span: 48.67 ft.
Total Span: 50.00 ft.
Bearing (lb): 8 in.
Live Load: 975 plf
Selfweight: 4662.6 lbs
Dist. Selfweight: 94.51 plf
Total Weight: 4725.7 lbs
CL Beam Stability Factor 0.979 - - - - -
CV Volume Factor 0.761b - - - - -
Beam Design Nick Bagatelos Reno Nevada 2023A78
3/14/2023 1
b = 10.750 in.
d = 37.500 in.
A = 10.750 x 37.500 = 403.13 in.2
Sx = (10.750)(37.500)2/6 = 2519.53 in.3
Sy = (10.750)2(37.500)/6 = 722.27 in.3
Ix = (10.750)(37.500)3/12 = 47241.21 in.4
Iy = (10.750)3(37.500)/12 = 3882.18 in.4
3/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [403.13 x (592.00 + 8)] x (12 in./ft.)3 = 139.97 ft3
Volumespan = N[A x L] = 1 x [403.13 x 592.00] x (12 in./ft.)3 = 138.11 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 139.97 = 4725.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 138.11 = 4662.6 lbs
Distributed Self Weight (ws) = = 94.51 plf
975 plf
  ws = 94.51 plf
49.33 ft.
48.67 ft.
50.00 ft.
28612.65 lbs
28612.65 lbs
3/14/2023 3
lu = Unbraced Length = 14 ft.
lu/d = = 4.48
le = 2.06lu = 2.06(168.0) = 346.08 in. = 28.84 ft.  (NDS Table 3.3.3)
Rb = = 10.60
 Rb = 10.60 < 50   ➜  OK
3/14/2023 4
FbE = = 9082.58 psi
CL =   = 0.979
CV = = 0.761
CV = 0.761 < CL = 0.979
Fbx' = (2400)(1.15)(1)(1)(0.761) = 2099.7 psi
fb = = 1658.3 psi
 fb = 1658.3 psi < Fbx' = 2099.7 psi  (CSI = 0.79)   ➜  OK
fv* = = 91.74 psi
3/14/2023 5
 fv* = 91.74 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
fv = = 105.05 psi
 fv = 105.05 psi < Fvx' = 304.75 psi  (CSI = 0.34)   ➜  OK
ΔLL = = 1.53 in.
(L/d)LL = 592.00 / 1.53 = 387
 ΔLL = 1.53 in = L/387 < L/360   ➜  OK
ΔTL = = 1.79 in.
(L/d)TL = 592.00 / 1.79 = 330
 ΔTL = 1.79 in = L/330 < L/240   ➜  OK
3/14/2023 6
Ab = b x lb = 10.75 x 8 = 86.00 in2
fc⊥ = = 332.7 psi
 fc⊥ = 332.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.51)   ➜  OK
3/14/2023 7
