Beam Design - Hillside Covenant Church
Selfweight: 38.7 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 39.5 lbs
Notes: Retaining Wall Replacement
Beam Design Ed Hultgren 1802 Wwhitecliff Way, Walnut Creek, CA 2023A74
3/13/2023 1
3/13/2023 2
ws = 3.30 plf
1069.77 lbs
1069.77 lbs
3/13/2023 3
fb = = 1726.2 psi
3/13/2023 4
fv* = = 98.38 psi
fv = = 113.24 psi
3/13/2023 5
ΔLL = = 0.27 in.
(L/d)LL = 141.00 / 0.27 = 520
ΔTL = = 0.48 in.
(L/d)TL = 141.00 / 0.48 = 292
fc⊥ = = 237.7 psi
3/13/2023 6
